throttle question M
e-manhunt
10-27-2007 18:50:43
I replaced the carb on my M. Got everything running fine --well, sounding fine. But the engine seems to run at one speed no matter how I move the throttle lever -wide open or way low. What am I missing? The master adjustment? Idle adjustment? Idle stop?
thanks
e-manhunt
10-28-2007 06:27:16
 Re: throttle question M in reply to e-manhunt, 10-27-2007 18:50:43
I am pretty sure this time that I got the notch fit into the square opening. I will have to take another look. Any other possibilities?
Andy Motteberg
10-28-2007 13:26:24
 Re: throttle question M in reply to e-manhunt, 10-28-2007 06:27:16
There is a speed adjustment screw in the carb. With the engine running, push the throttle lever all the way forward, turn the speed adjustment screw out and see if the engine speed slows down.
georgeky
10-27-2007 19:55:49
Yep, I would say Andy hit the nail square on the head. The shaft and notch have to line up properly. Have put mine together before and missed it too.
Andy Motteberg
10-27-2007 19:05:36
Make sure that the governor shaft engages the slot in the carburetor throttle shaft, if it does not, it will run at one speed. I had that problem with my H Farmall once.
