806 engine
wegman in mn
10-27-2007 19:51:16
will the 806 d engine fit in the 100 hydro? thanks,
K.B.-826
10-27-2007 20:05:29
 Re: 806 engine in reply to wegman in mn, 10-27-2007 19:51:16
The flywheel may be a problem. You'll need to determine if the Hydro 100's flex plate bolts up to the 806 flywheel. If not, you'll probably need to find a flywheel for a 1026 tractor, the only Hydro to use the 361/407 style engine. You'll also need some spacer plates between the front engine cover and frame rails, because the 100 will have the wider frame like the rest of the 66 series. I question why you want to do this. If you've got a 100 with a blown engine and a good 361 sitting around, sell the 361 and buy another 400 series engine to put back in the 100. A running 361 will bring good money, and any 400 series enigne from 66-88 series will bolt in with a few parts from your 100's engine.
Jim J
10-28-2007 21:40:50
 Re: 806 engine in reply to K.B.-826, 10-27-2007 20:05:29
The 806 flywheel will work.
