mag problems on U1
new to IHC
10-28-2007 10:48:50
Can anyone tell me where I can get information on how to work on a mag for a U1 power unit. The mag is the same as on a cub. The serial mumber is J4159281. It fires weak and I am not sure if I have it in time or not. Thanks for any information. Johnny.
El Toro
10-28-2007 14:23:31
 Re: mag problems on U1 in reply to new to IHC, 10-28-2007 10:48:50
third party image
If you pulled the mag this may help. You can't use the screwdriver since the valves are in the block. Hal
John M
10-28-2007 17:39:53
 Re: mag problems on U1 in reply to El Toro, 10-28-2007 14:23:31
Yea you can, in through the spark plug hole. Done it several times. Thast why they say a LARGE handle screwdriver, so it wont fall into the hole. Just have to be easy pulliung on the handcrank.
new to IHC
10-28-2007 15:15:43
thanks El Toro
new to IHC
10-28-2007 12:47:03
Bob
Thanks for the help. I found the site you told me about and it had some helpful information. Thanks again Johnny.
Bob
10-28-2007 11:11:49
Timing... the impulse should "trip" @ #1 TDC.
Need more info? I thought I posted the link to Rudi's Cubs for you a couple of days ago?
ANYHOW, here's the link:
Link
Your mag is covered on pages 3, 4 ,6, and 6.
