Farmall 300 350
DougSr
10-29-2007 18:33:57
Hey guys I came from the green tractor site but like all colors. What is the diffrence in the Farmall 300 and the 350? A friend and I went and looked at one the other night and he bought it. We have not went and got it. You can't read the data plate. The numbers is not on he hood. It als has the two point hitch on it. The guy said it used to have dual wheels on it. Thanks a lot. Doug
D Slater
10-29-2007 19:12:59
 Re: Farmall 300 350 in reply to DougSr, 10-29-2007 18:33:57
If tractor hasn't had parts changed around a 300 will have the key switch in dash or gage panel. 350 key switch is down below panel on left side with a push button in gage panel to send power to starter solinoid. Rear light was mounted on right side of battery box 300, left side 350. On side of engine block above oil filter and tappet side cover should be in raised cast C 169 for 300. C175 for 350. Look at clutch pedal below piviot point at botom. 300 will have a bolt with lock nut to limit lever travel. 350 clutch pedal end won't be drilled for the bolt. There's some more different, but that should tell you.
Pat-CT
10-29-2007 18:33:39
engine size and thats pretty much it that and the cream colored paint on the sheetmetal look up 350 on the photo section to your left and ull see the cream colored paint im talking about
