mccormick deering 22-36...PIC
Josh SD
10-29-2007 18:48:06
third party image
Well hopefully I got the picture to work but it's the 22-36 I got last March and this is how I bought it. Over the summer I have had the head gone through, replaced many of the gaskets, put on the manifold, carburetor, rocker arms, and just about everything else is done. All that is left is to add oil, antifreeze, and gas. Do any of you guys know what weight of oil to use? After dad and I get the corn out probably going to have to try and get the old beast started...neighbor says he starts his by putting a belt on another tractor's belt pulley and putting it on the non-running tractor's belt pulley...we'll see how that goes one of these next weeks...I'll get some more pics soon...
Josh
Bob Kerr
10-31-2007 10:54:32
 Re: mccormick deering 22-36...PIC in reply to Josh SD, 10-29-2007 18:48:06
If you have the oil pan cleaned out and the head redone (cleaned up) detergent oil will be what I would use as long as the engine has an oil filter. 30wt is the stuff.
LenNH
10-30-2007 08:40:57
The "common wisdom" when detergent oils started becoming popular (after WWII, as I remember) was that you should NOT put detergent oil in an engine that had been run for a long time with straight oil. Supposedly, the detergent would loosen up all sorts of stuff that had accumulated in the oil system. Don't know if it is true, but my father--an avid reader of auto mechanics' journals--used to tell me this. I am assuming that you know all about impulse couplings, making sure they are set (easy to forget when the coupling has to be set manually), etc., and that you know that pushing DOWN on a crank is a great way to break your arm. My father had his arm broken cranking a Ford, when he tried to spin it to get better spark (the Ford mag, on the flywheel, had no impulse starter, so the juice got better when you spun the engine faster). An impulse starter won't give you any better spark from spinning the crank, I think. The spin given to the mag after the impulse trips is pretty good, and would probably give a better spark than you could get by spinning the engine without the impulse (ouch!). When I used to crank these beasts (10-20, F-20, "Regular," F-12, Oliver H-P Row-Crop), I always retarded the spark for extra safety. I still don't know if this retarded the spark beyond what the impulse does.
Hope I'm not telling you what you already know, but I just wanted to add these words about safety.
red460
10-30-2007 04:14:47
22-36 is a handful to start with a crank especially if its not been run in years. Belt wheel to belt wheel is an excellent choice. Get the belt on so the 22-36 is turning the right way and let out the clutch. This is a good way to dial in the carb and mag. I like to use a non det heavy wt oil but have friends who use det in old tractors with no problem.
F-Dean
10-30-2007 04:11:09
I have used 10W30 automobile oil in my tractors with the dipper systems (F-20, F-30 and W-30) without any problems and no foaming.
James Williams
10-29-2007 19:39:05
josh,My understanding is that you should use non-detergent oil becaues detergent oil will foam with the dipper system
jimmy
Loren in Iowa
10-29-2007 19:30:34
Josh-We've used either straight 30w or 15w40 in our 15-30, which is an earlier version of the 22-36. You might be able to start her up with quarter turns of the hand crank, if everything is tuned up right.
