Value fo a super mta
Jeff Siemandel
10-30-2007 13:23:12
Found a Super MTA, with picker ,sitting for about 7 years.Still turns over, that's the good news.The nose piece, fenders are gone and no where to be found,tires are flat, but should hold air. What is a fair price for this? On the good side it's close to home.Thanks In advance Jeff
BOBM25
10-31-2007 09:14:21
 Re: Value fo a super mta in reply to Jeff Siemandel, 10-30-2007 13:23:12
For 900 bucks I'd buy and not think twice. If it's not stuck, I would think it should run. I'm not too afraid of an unstuck motor. Heck, I've heard of guys breaking loose a stuck motor, then getting to run. I'd go $1500 sight unseen, probably a little more once I personally checked it out, though.
big red 1
10-31-2007 06:25:14
Tires-expensive-tin work-getting harder to find decent stuff-when you do it is expensive.
A lot depends on restore it,keep it show it,or try to make a buck on it.
My experiance with a Super M found with a picker on it-similar situation is about 2200.0 later and ready for paint.After 1000.00 on tires I quickly figured out that this unit will be a lifer in the fleet
SDE
10-30-2007 16:16:12
You will also be looking for a hitch for it. If the tires are not cut from the rims pinching them, you should consider yourself very lucky. I would assume that it ran when they parked it and that it should not take much to get it to run again.
You could have about $700 in the replacement of the hitch and grill parts.
SDE
Pat-CT
10-30-2007 15:34:12
fenders are usually gone tires are expensive good luck
Dave H (MI)
10-30-2007 14:54:24
Make sure the tires hold air, check out the cost of the missing parts. If it still runs and you can get it for Jim's price I would buy it. Tell us where you are as I would be interested in the picker.
JEff Siemandel
11-01-2007 07:02:45
 Re: Value fo a super mta in reply to Dave H (MI), 10-30-2007 14:54:24
Reedsburg Wi.
Janicholson
10-30-2007 13:31:29
Picker as is probably scrap price 100 (guess) Not terrific interest in them.
SMTA not running, on flats 900$. Turning is one thing, cracked and dammaged internally is another. Consider it easier to rebuild than one that is stuck. JimN
