International Harvester 140
mud remover
10-31-2007 13:35:58
Where can I find a decal set for this tractor ?
I have found some on this site, but I am not sure if it is the correct one. The listing does not show what comes with the set.
Does anyone know of other resources?
Thank you.
mud remover
11-01-2007 05:36:27
 Re: International Harvester 140 in reply to SuperA-Tx, 10-31-2007 13:35:58
Hugh MacKay said: (quoted from post at 02:01:43 11/01/07) As randy pointed out over the years there have been several different decal configurations used on 140. If you come up with a serial number, I can tell you which type is appropriate.
the serial number is 54286 stamped on the ID plate
this one had sheet metal parts with emblems : "140", "McCormick", "International" ...
Hugh MacKay
11-01-2007 15:45:42
 Re: International Harvester 140 in reply to mud remover, 11-01-2007 05:36:27
According to that serial number, your tractor was the 13th one built in 1975. It apparently has the wrong decals. The name "McCormick" does not appear on any International tractors after 1967. Plated metal decals were not used on 140s after 1963.
What your tractor should have are adhesive decals, with the word "INTERNATIONAL" each side on the hood. Then down on lower portion of sheet metal over radiator a model badge, wider at top than bottom, with the word "FARMALL" in inch high latters and below that "140" , in 2" high numbers. The above are all adhesive.
On the grill near top, in red and black is white metal IH emblem with I in the middle of the H.
Hugh MacKay
10-31-2007 18:01:43
 Re: International Harvester 140 in reply to mud remover, 10-31-2007 13:35:58
SuperA-Tx
10-31-2007 14:27:47
Maple-Hunter lists a set for 140's. In fact they show three sets; blk / gold, blk / chrome, and Clear blk / chrome.
Phone/Fax 812-894-9759
SuperA-Tx
10-31-2007 14:33:56
 Re: International Harvester 140 in reply to SuperA-Tx, 10-31-2007 14:27:47
Missed one.
This is for "McCormick Farmall", 17" blk/wht/gold
First two they list are for International 140's and the third they say is for Hi-Clear then the fourth for McCormick Farmall
