F 12 aux. transmission
richwill
10-31-2007 18:19:33
third party image
I am looking for a add on gearbox for my F12 to giv e more speed in road gear. Does the gearbox bolt in the space between clutch & transmission?I drive my f 12 in parades & keep my garden plowed with it. Sure could use a little more speed because garden is on a spot 1/4 mile from house. Am also looking for an original stearing wheel for f 12 it is 16 in diam. Any info will be very much appreciated THANKS
LenNH
11-03-2007 13:58:57
 Re: F 12 aux. transmission in reply to richwill, 10-31-2007 18:19:33
A good (and original) solution is to try to find the IHC option, a "7 mph road gear," which the company offered after rubber tires became available. At high-idle, you should get about 8 mph, which would get you over the 1/4 mi. pretty fast. I can't tell you how many hours I've spent going back and forth a mile each way with a wagon to pick up hay or grain, pulling with an F-12 at 4 mph. I don't know how complicated it is to install these gears.
richwill
11-01-2007 18:25:53
Bob you dont know how many times I have heard that exression it was my dads favorite saying word for word THANKS
Rich
Bob Kerr
10-31-2007 20:32:56
The heisler unit mounts on the input of the trans. You have to remove the shield and the coupler and the part that bolts onto the housing. The OD unit has the gear mounted on it that matches up to the gear inside. Then add back the coupler parts that will line up. and figure out where to mount the control rod. It may be a good idea to also take the belt pulley off as it will spin like mad with the overdrive on it and it will take a blue moon to be able to shift gears without grinding. The pulley may also be at risk of flying apart. There may be another type of OD that someone else may know about. My experiance is with the heisler.
Bob Kerr
10-31-2007 21:46:39
 Re: F 12 aux. transmission in reply to Bob Kerr, 10-31-2007 20:32:56
Forgot to add, nice tractor! It looks purtyer than a speckled pup under a red wagon!
