MW to a IH Pump
Rich Griffin
10-31-2007 19:16:23
I have this MW live pump on a M that went bad and thinking about putting a MTA-400-450 pump on it. Was wondering if the timeing cover and back plate has to be changed. Thanks
glennster
11-01-2007 08:21:28
 Re: MW to a IH Pump in reply to Rich Griffin, 10-31-2007 19:16:23
rich, i put an m+w live pump on my 48 m a while ago. bought the pump at a sale, new in the box with instructions. the top two bolt holes on the tractor needed to be plugged and redrilled and tapped. not hard to do, then the pump will work. it is the same mount as the i-h pump. so probably if yours has the m+w pump, the front cover has already been modifyed to fit.
D Slater
11-01-2007 14:17:16
 Re: MW to a IH Pump in reply to glennster, 11-01-2007 08:21:28
Another new one to me, all the old M&W hydraulic pumps for M tractor had the top 2 holes sloted to fit both covers.
D Slater
10-31-2007 21:49:30
If your tractor is a 1950 there's a engine serial # break on the front cover and plate to the correct bolt pattern for the IH pump. If its older the bolt pattern is different. If newer the same bolt pattern as IH pump. On some M front covers though the pump shafts with snout for a hour meter drive gear will contact inside of cover just before a flush bolt up. This is just a guess on engine serial # break without looking it up, but I seem to remember it may be 228050.
