S M Head number
Buck E
10-31-2007 20:06:48
A while back I tried to find out what kind of head was on my 1952 S M. I gave the block number instead of the correct #. Took valve cover off and # on head is 362174-R1 . Is this a 400 or 450 head? Has no vent pipe connection at back. Thanks for your help. Buck E
Buck E
11-01-2007 09:27:48
 Re: S M Head number in reply to Buck E, 10-31-2007 20:06:48
D. The tractor serial #is F2094J. Engine serial # is 2185K.All cast numbers on tractor are in march 1952, so this was early SM. By the way . I drilled a hole in back of valve cover and with fitting and hose, hooked to Air cleaner connection, also put 1/4 in. pipe in front where oil was draining to gov. It works like supposed to an no oily smell. Thanks for your help. Buck E
D Slater
11-01-2007 14:23:59
 Re: S M Head number in reply to Buck E, 11-01-2007 09:27:48
Interesting, the K means your SM came with castiron pistons. Forgot to put in other post that the head was also put on the first 400 LP tractors before they started using the smaller combustion chamber head on 400 and 450 LP tractors. Good luck
D Slater
10-31-2007 21:37:00
Yes, 400 and 450 series gasoline head. There's a chance the whole engine was changed,you posted before the block # 356980R1. Thats the same # used for a SM and early 400 tractors. I could tell you by the engine serial # which it is.
