Super A Hydraulic fluid recommendations
SteveNH
11-01-2007 05:52:10
Hi, I searched the forum and found that a lot of people are using a variety things for the hydraulic fluid. 30W oil, gear oil, and other weights. So I am confused as to what I should use - I thought they made hydraulic fluid like tractor 303 or something. I looked in the tank under the gas tank and it appears to be only 1/2 full, or 1/2 empty. I am planning on changing out the fluid and am not sure what to put back in. I&T said a little over 4 pints and fill it within a 1/2 inch of the top cap.
gene bender
11-02-2007 03:45:19
 Re: Super A Hydraulic fluid recommendations in reply to SteveNH, 11-01-2007 05:52:10
The SA was built before hy-tran. When new 30wt oil was used its your money.
SteveNH
11-01-2007 16:08:53
 Re: Super A Hydraulic fluid - Filter Location? in reply to SteveNH, 11-01-2007 05:52:10
Looking at the I&T diagram it looks like the strainer - assuming this is the filter - is on the left of the drain plug hiding behind 4 bolts, is this correct? I didn"t want to take more apart than I need to since I am a "If it"s not broke don"t fix it" kind of guy. I know these older things can get worse if you try to "fix" them.
SteveNH
11-01-2007 15:55:25
Thanks for the help. I will pick up some Hy-Tran tomorrow. Also, thanks for the suggestion about cleaning out the filter, I will do that as well. I will bleed the system as noted in the I&T - if I run into trouble I know where to find help.
Thanks.
dhermesc
11-01-2007 11:14:56
I agree with the post below, pull the filter and drain what's there. Hard telling what's been added in the past.
Given the price of "real" IH Hytran I'd buy a hytran equivelant at TSC or even Walmart. It will do fine in a Sauper A.
Steven f/AZ
11-01-2007 08:17:57
I use Hy-Tran in all my hydraulic systems, including IH live pumps, Cross brand pumps, IH belly pumps, almost everything we have gets Hy-Tran... except for the JD tractors, which get Hy-Gard.
scotty
11-01-2007 08:17:47
Mornin Steve, As Hal recomends use HY-Tran which you can get from your Case IH dealer. I use it in my Touch Control on my Super A. I might suggest that you pull your filter out and clean that before putting in ne fluid !
scotty
El Toro
11-01-2007 06:47:26
I would use a good grade of hydraulic fluid such as HyTran or HyGard or one that is compatible.
Hal
mark
11-01-2007 09:27:45
 Re: Super A Hydraulic fluid recommendations in reply to El Toro, 11-01-2007 06:47:26
I use ATF in mine. I rebuilt the reservoir and flushed the system before putting it back together. I bought some Dexron and refilled the reservoir and have been a happy camper.
El Toro
11-01-2007 10:20:44
 Re: Super A Hydraulic fluid recommendations in reply to mark, 11-01-2007 09:27:45
I use Dexron in my garden tractor hydrostatic drive and the hydraulic lift. For the last 36 years. Hal
