C123 sleeves
Doug C.
11-01-2007 11:08:31
Took the pistons out of my SC last night. Didn't have enough time to drop the crank, but took a quick look from below. Are those JUST the sleeves protruding down from the block, or is that a cast flange? I hope it's just the sleeves - piece of cake to tap out from below once I remove the crank.
Thanks
S/C BOB
11-03-2007 19:37:43
 Re: C123 sleeves in reply to Doug C., 11-01-2007 11:08:31
I have a complete rebuild kit for that engine if it has 3" pistons. i bought it for my tractor but i ended up buying another engine.If interested 423-239-3790...
gene bender
11-02-2007 03:37:49
Most of the time you will a sleeve puller good luck on tapping out.
El Toro
11-01-2007 12:05:39
third party image
You can build a puller like Keith's. Hal
Doug C.
11-01-2007 12:32:11
 Re: C123 sleeves in reply to El Toro, 11-01-2007 12:05:39
Thanks El Toro, Forgot about the flywheel - getting ahead of myself. Hopefully They will tap out without a puller. Everything seems nice & loose (hence the rebuild!)
El Toro
11-01-2007 12:52:51
 Re: C123 sleeves in reply to Doug C., 11-01-2007 12:32:11
You need to measure that crankshaft for being eggshaped or worn. I would pull the engine and then you can examine the clutch fo wear. That block area needs to cleaned where your sleeve seals are and at the top of the block where the recessed area is for the top of the sleeves. Hal
El Toro
11-01-2007 11:54:24
You can bump them out from the bottom with a piece of 2X2 oak and a hammer and just tap on them. They're not pressed into the block.
If you don't have engine off the tractor I don't think you get the crankshaft out. Your flywheel and clutch are all connected to name a few items. Hal
