help assembling a sicle bar mower
Pat-CT
11-01-2007 13:40:17
ok so at school we have this super C and a bunch of current tractors but the suuper c is the best one there in my opinion ive spent 2 classes working on it and got it running now i need to assemble the sickle mower for it does any one have a picture of a c or super c sicle mower of how it mounts on and all the parts
georgeky
11-01-2007 22:01:30
 Re: help assembling a sicle bar mower in reply to Pat-CT, 11-01-2007 13:40:17
Pat, it could be a 21 as Scotty said or a 24. They look almost identical. I have one of each and the only difference I can see is the 21 has one spring on the back and the 24 has two. They called this a heavy duty mower. If you email me, I can send pics of both. I have mowed many acres over the years with mine. Like said it is a fairly straight forward mounting. You need the axle clamps and it bolts right up. It can mount in the right hand axle notches or left. They are very good mowers. They do rattle and shake a bit, but that is normal for most pitman mowers. They ride very close to the ground which will stick you when crossing ditches and such. When in good shape that mower and a good C/SC will mow with anyones outfit. Better than most.
Dave H (MI)
11-01-2007 14:16:09
I'll bet there is a manual on that item you could get a hold of that would be your best reference. Are you familiar at all with sickle mowers? Make sure you keep your fingers clear when moving the cutter bar or it will slip and cut your finger to the bone...or worse.
ScottyHOMEy
11-01-2007 14:13:10
"and all the parts" makes for a pretty tall order there, Pat! Is the mower a Model 21? That is, does it have two upright brackets at he front of the frame, with a notch cut into the curve at the top of the uprights? Does anybody know if this mower's been mounted to that tractor before? The only pictures I have of mine wouldn't show any detail that would be useful to you, I'm afraid.
There's a lot of parts on one of those, and a fair number of adjustments to make them run right. Not hard to make they just have to be right.
Binder sells a reprint of the manual for the A-21 and C-21, that's exeptionally good, Has assembly, operation and maintenance instructions all in one small book AND a parts list! It's a bargain, and I'd recommend it.
If it is a 21, it mounts up using two axle clamps, that bite onto the notches on the rear axle. Not centered, but offset to the right, by moving the clamps to the right-hand notch on each axle. Those clamps are critical. Not always easy to find if you don't have them, but they are out there.
Lifting the bar is accomplished by connecting the lift crank to one of the lift cranks on the left side of the tractor. The original connection seems, from the book, to have been a rod. The rod is gone on mine and is connected with a cable.
It would make for a good project, if you can get it on and running. If somebody else can come up with some pictures to get you started and/or you can get that book, I'll be happy to share whatever experience I have that would be useful to you.
