super c hitch
Pat-CT
11-01-2007 13:49:29
the super c at school has some kind of weird hitch on it the fast hitch is on the bottom right ? this one has a rod that travels from the back of the tractor up above the clutch pedal and into a piviot point in the middle what kind of hitch is this????
Pat-CT
11-02-2007 14:21:28
 Re: super c hitch in reply to Pat-CT, 11-01-2007 13:49:29
looks exactly like that hnadyman can you give me a couple more pictures of how that plow hooks on
Handyman
11-01-2007 19:47:18
does it look something like this?
third party image
Mark Peters
11-01-2007 16:12:03
Without a picture to go on, I`m going to take a guess.It does`nt sound like its any part of a fast hitch. It sounds like you`re describing the lift mechanism/rockshaft for rear mounted plow.(Not a fast hitch) This would function similar to the lift mechanism on the Super A - 140 non fast hitch models.
ny bill
11-01-2007 16:05:57
it sounds like you are describing the arm that controls the sideways tilt of the implement on the fast hitch. the back end of the arm hooks to the curved arm that comes up under where your left heel would be when you sit on the seat. move the pin that holds arm #2 rigid, into the upper hole and through arm #1. the tilt adjustment is especially useful when plowing (starting a back furrow) and finishing (on the dead furrow).
Pat-CT
11-01-2007 13:50:09
oh and it connects to the impliment almost at seat height
