farmall mdta
eric eisenhardt
11-01-2007 14:20:39
got a mdta starter that is gone. the front of the nose cone went past the brass bushing and is way out of round cant find a nose cone to match the bell housing. it is differnt than a md or a 400 were do i go i looked everywere cant find one
help eric
Bob
11-01-2007 18:41:22
 Re: farmall mdta in reply to eric eisenhardt, 11-01-2007 14:20:39
Have someone with a vertical mill straighten out the bore, and use a oversized bushing
Haas
11-01-2007 18:30:46
I have several new old stock starter nose cones. Don't know what the fit, or even if they have numbers on them to ID, but if you have a part number, I'm willing to take a look and see if one of them is what you need.
D Slater
11-01-2007 16:07:54
I'm only aware of starters like yours being used on stage 2 SMD, later SW6 and SW6TA if you want the original type. Some later diesel starters will bolt up and work,but they use a different type of engagment and starter switch. MD and stage one SMD won't work.
CENTAUR
11-01-2007 16:04:27
It might help if you could post the BRAND and MODEL# then someone with access to the parts cross referance may be able to help. CENTAUR
