super m cylinder head studs
glennster
11-02-2007 05:38:18
got the studs pulled on the super m motor. there are 4 studs about 1/4 inch longer than the rest. see photos for location they were in. is that correct? the last motor i did was an m and the longer studs seemed to be on each end and down the middle. i dunno, i ferget.
third party image
third party image
Owen Aaland
11-02-2007 22:04:52
 Re: super m cylinder head studs in reply to glennster, 11-02-2007 05:38:18
The four longer bolts are used, two where the bracket for the throttle pivot attaches, and two where the thick washers are located. If you look closely at the head you will see two stud holes that are tubes pressed through the head. That is where the washers belong.
D Slater
11-02-2007 05:47:43
Correct, thick flat washers go under nuts on 2 closest to center and throttle linkage piviot stand on 2 near edge. Good luck
glennster
11-02-2007 05:59:41
 Re: super m cylinder head studs in reply to D Slater, 11-02-2007 05:47:43
thanks for the info, i wasnt sure and it kinda dint look right, but that makes sense. glenn
