Farmall Main Bearings
Mike Farmer
11-02-2007 10:10:09
Greetings to all the big red folks out there. I am still searching for a set of +040" or +050" or +060" oversize crankshaft/main bearings to fit a 1949 Farmall M. None of the main dealers have them in stock or even available to order. I can get a +060 single centre bearing. Does anyone know of a dealer or a hoarder( like me) who has a batch of International 'new old stock'who just might have what I need. If so I shall be eternally grateful if you can get them to contact me on this site. Thank you in advance Mike Farmer
r4etired
11-03-2007 19:00:37
 Re: Farmall Main Bearings in reply to Mike Farmer, 11-02-2007 10:10:09
Remember M cranks after 278XXX have larger journals than earlier.
Mike Farmer
11-03-2007 13:15:15
Hi because I'm reasonably honest I did a bit of reading(within my obviously limited capabilities) and find that indeed we are using both methods to identify oversize/undersize bearings. that is +040" and.040 Incidently I tried using it as an anchor but when I pulled it up it was still basically the same but it went a sort of rusty colour please advise if that was supposed to happen.Mike Farmer
Mike Farmer
11-02-2007 16:39:18
This is just a cross atlantic change of terminology. We call them +040 etc. Up to +060" were definitely manufactured. Sadly there aren't 'plenty of good ones about' in England. But thanks anyway Mike Farmer
El Toro
11-02-2007 17:24:23
 Re: Farmall Main Bearings in reply to Mike Farmer, 11-02-2007 16:39:18
There's plenty of good used crankshafts available
and some of those M's used the Super M crankshafts
starting with SN 278050. Hal
Steven f/AZ
11-02-2007 14:39:11
I"ll bet you can find a crankshaft that only needs to be cut .010" a lot cheaper than a set of NOS .060" bearings (if they even exist).
Janicholson
11-02-2007 13:10:23
Please accept this as information not ignition!!
Journal bearings (man=ins and rods are undersized not + sized. One asks for .010' under bearings. I have never herd of bearings more than .030" under for farmalls. JimN
John M
11-03-2007 05:15:02
 Re: Farmall Main Bearings in reply to Janicholson, 11-02-2007 13:10:23
Undersized journals, oversized bearings? I never worried about since my parts man knows what Im talking about.
El Toro
11-02-2007 14:29:18
I think they call them oversize since they're thicker, still are known as undersize. Hal
Renee Booth
11-02-2007 11:46:43
Give Broke F Farm Supply a call. They have had everything we needed for our 1939 H. 903-886-8775. Speak to Karen or Billy. They are great and will ship parts for you. They are located in Commerce, Texas.
the tractor vet
11-02-2007 10:39:38
TO my knolage they never made a .060 over bearing and the best you will find will be a .040 . So if your crank is that bad then it is good for a boat anchor .Time to look for a good crank. And there are enough of them out there.
El Toro
11-02-2007 10:33:45
It would probably be easier to find a good used crankshaft for your tractor. Hal
Red Dave
11-02-2007 10:15:05
Give Weber's Tractor Works a call, they have that type of thing.
Here's a link:
