Super A with anti freeze in oil pan
Red State
11-02-2007 10:31:20
Hi, I need some suggestions about this tractor. Every year when we get ready to put up hay, I change the oil and it has Antifreeze in it. I suppose during the season it stays mixed up in the oil but during the winter it seperates. Where ever its coming from it doesnt not seem to effect the running of it, no smoke and obviously its still running strong and cuts hay like the big boys. Any ideas? Thank you
Red Dave
11-02-2007 10:44:43
 Re: Super A with anti freeze in oil pan in reply to Red State, 11-02-2007 10:31:20
Some possibilities, in no particular order:
Bad Head Gasket
Leaking O-Ring seal at the bottom of one or more sleeves
Crack in the head
Crack in the block
If I was you, I'd hope for a head gasket. It's fairly easy and cheap to replace them.
El Toro
11-02-2007 10:44:25
You may have one of the sleeve seal's leaking. You would need to remove the pan after draining the oil and shine a light around the base of the sleeves and see if any are wet with antifreeze.
Set a clean container under the engine over night and see if any drips into the container. That antifreeze isn't too good on bearings. To replace those seals is almost a complete engine teardown to get to the seals. The head, oil pan
and rods & pistons would have to be removed. Good winter project. Hal
