53 supper fc; SC puller update
Keith-OR
11-02-2007 10:43:38
I made a new one(puller), modifying existing design. I used 5/8 althread instead of 3/4, since I used the 5/8 to press pulley back on. I took some pictures yesterday afternoon of installing pulley using the hydraulic jack and the other part of my press. I used a core engine with pulley a friend has, so people will beable to see how I used the 14 inch bar to re-install pulley, bolts are in the upper left and lower right bolster bolt holes on the engine. Also I used a piece of metel in between the jack ram and the pulley, which I did not have it with me yesterday. Anyway you get the idea. :lol:
Knowledge and experiences are NO GOOD unless it is shared. third party image
If anyone down the road needs the design and I'm not on the forum, just email me... I'll be glad to furnish info.
Keith & Shawn(Special Olympic Champion)
PS. the nuts just below the bar should be against it to hold it in position!!third party image
third party image
Idaho Ron
11-03-2007 22:17:53
 Re: 53 supper fc; SC puller update in reply to Keith-OR, 11-02-2007 10:43:38
George, we had to get rid of the scrap pile at work. I about cried! I don't have anything to make anything now. Ron
scotty
11-02-2007 11:15:09
Afternoon Keith, Glad you got it back together, but personally I wouldnt go through all that aggravation myself !!! There was something like a .002 press on that pulley. I used a flapper wheel and opened that pulley up to the point it would go on with a tap fit. I installed a 1/4" set screw on top of the woodruff key and it works great ! Thats just a suggestion if you do any more rebuilds. JMO !
scotty
RustyFarmall
11-02-2007 10:52:13
Where there's a will, there's a way. Thanks for sharing that pic. Gives me one more reason to NOT get rid of ANY of my scrap iron.
georgeky
11-02-2007 13:45:06
 Re: 53 supper fc; SC puller update in reply to RustyFarmall, 11-02-2007 10:52:13
One should never part with any scrap iron. You will need it for something sooner or later.
