What are these?
Steve in S. IL
11-02-2007 18:31:31
third party image
I collect AC stuff and these parts were with some AC things I bought today at auction. Can anyone help me identify any of these parts and tell me if they are worth selling?
Thanks,
Steve in S. IL
J.J. from Afton
11-03-2007 05:18:47
 Re: What are these? in reply to Steve in S. IL, 11-02-2007 18:31:31
THe piece in the top left looks like something off a Massey Ferguson 35 or similar.
don g
11-03-2007 05:10:06
what part of s il im from the st louis area
richwill
11-02-2007 20:30:36
The disk on right top looks like adapter to comvert from canister oil filter to spin on. The 6 injectors look like out of 100 series Ford diesel but only 4 cylnd 1950s
glennster
11-02-2007 19:20:44
that thing in the top center looks like a governor out of maybe a farmall a or b. the shaft to the right of it sort of looks like a starting crank extension for a tractor with a trip bucket loader. cant see if it has notches or not. next deal looks like half of a 2 piece pulley sheave.
Bob
11-03-2007 00:34:51
 Re: What are these? in reply to glennster, 11-02-2007 19:20:44
The governor is for an "N" Ford. The 9N, 2N, and 8N units are all similar. The differences are in the levers, partially hidden in the picture. From what I can see of the levers, it APPEARS to be a 8Nunit, 'cause one ball stud faces each way.
8N syle levers..
Third Party Image
9N, 2N style levers...
Third Party Image
The pump at the upper left, because of it's apparent small size, appears to be an engine oil pump, I know I SHOULD recognize it.. Case or Massey, perhaps???
Dairy farmer in WI
11-02-2007 19:06:24
well the bottom 6 things look like injectors out of an older case. second from the left looks kinda like a live hyd pump for a M Farmall but the gear teeth look way wrong. that's my guess. don't know bout the rest.
