M axle leak
Carden
11-03-2007 04:02:24
Well, replacing the seal and outer bearing appear to have solved the leaking axle issue. I appreciate all of the advice, again.
Janicholson
11-03-2007 08:32:33
 Re: M axle leak in reply to Carden, 11-03-2007 04:02:24
I'm glad it is working. If the axle tightened up when the bearing was installed it will be fine. If the play mentioned in your first post is reduced to just a few thousandths, it will be a good fix. JimN
