I NEED HELP WITH MY F-20
STEWARTINPA
11-03-2007 04:28:37
I AM RESTORING A F-20 AND I HAVE GOT ALL THE PARTS COLLECTED NOW. BUT I CAN'T SEEM TO FIND A TORK SETTING FOR THE ROD BOLTS AND WHAT SHOULD I SPACE THE VALVES AT? THANKS STEWART
STEWARTINPA
11-04-2007 01:16:25
 Re: I NEED HELP WITH MY F-20 in reply to STEWARTINPA, 11-03-2007 04:28:37
THANKS GUYS FOR THE HELP STEWART
SproutW
11-03-2007 11:59:16
I've always gone 90 ft.lbs. of torque on the head bolts and 35 to 40 ft.lbs. of torque on the rod bolts.
the Unforgiven
11-03-2007 07:39:36
Hi Stewart,I set the valves at .012-.014 cold, the owner's manual says .009 hot. I have never seen a published value for the rods or headbolts, as for the rods the clearance is more important than the torque value, I try to get the shims right and then tighten the caps down good, then check to make sure the rod bearing is not tight on the journal. For the headbolts I go 100lbs. with clean, oiled threads, but I am always nervous as the only headbolt I ever broke was on the first F20 I had.
