Re: Value of IH 2001 loader
PUTTER
11-04-2007 06:01:35
Hey Al, I paid 1,100 for mine this spring. It came off of a 560 I think. I got a manual from Binder books and it shows all the different mounting brackets. I'll have to fab up new brackets and cut some of the box beam off to make it fit. It has the single cylinder for dumping the bucket. I'm suprised yours is a trip bucket. I see on mine that the dump cylinder mechanism is bolted on instead of being welded so you must have been able to get it either way. I'm still trying to figure out how much to cut out the box beam. By the way, the bucket on mine is pretty beat up but the frame is in good shape. Later PUTTER
Al L. in Wisc.
11-04-2007 17:35:01
 Re: Value of IH 2001 loader in reply to PUTTER, 11-04-2007 06:01:35
PUTTER, a thousand pardons for not getting back to you on that 2001 loader. Mine is still sitting on the trailer awaiting some parts as I called IH dealer Friday p.m. I need to get you length measurement from backside of 'front channel' to where ?? on frame? Yup, the front cylinder was optional. According to the Operator's Manual: Double-acting lift cylinders are not applicable on Farmall 240, 404, 340 and 504 and International 240 Utility, 404, 424, B-275 and B-414 tractors. Do you have the Operator's Manual also? W/double-acting cylinders and the trunnion mounted cylinder, you probably got a fair deal, IMHO.
