Farmall H Questions
olrusty
11-04-2007 10:27:58
How can I tell of the difference between the Farmall H regular fuel and the All Fuel engine?
Second question is the H I am rebuilding has a cover over the exhaust manifold. I have never seen this before. Is this just a rare heat shield?
Thanks
Mike CA
11-05-2007 07:43:39
 Re: Farmall H Questions in reply to olrusty, 11-04-2007 10:27:58
Steven f/AZ said: BTW that heat shield is worth some fair $$ on eBay...
SHHHHH HHH!!!! I was gonna buy it from him!! third party image
minnmeyer
11-05-2007 02:54:07
My 40 H does not have a petcock in the carb. bowl.There is a plug in it,and my H is a distillate.Go by the serial number.Also is there a pony tank still on this H.Or is there a hole in the hood tin where the fill spout for the pony tank went thru.Check manifold for funny looking little lever,and another thing to check would be are there louvers in front of he radiator.
Andy Motteberg
11-04-2007 11:32:19
A Gasoline tractor has a drain plug in the carburetor bowl, and the all fuel models have a petcock in the bowl. A gasoline tractor serial number ends with X1. Manifold heat shields are pretty hard to find, I've seen them go for $100+ on eBay.
Steven f/AZ
11-04-2007 11:05:36
A heat shield on the manifold points to being a distillate tractor... if your serial number does not have a suffix, it would be a distillate tractor as well.
Also, you can check the head casting number and post it back here and someone will know if that is a gas or distillate head.
