450 Gear case oil
Bill Thompson
11-05-2007 04:31:51
What oil is recomended to put in the gear caseing and how much? (after I find all the leaks)
champspa
11-05-2007 14:12:24
 Re: 450 Gear case oil in reply to Bill Thompson, 11-05-2007 04:31:51
mine takes 15 gallons of hy-tran the plug is one the side below the ta lever
the tractor vet
11-05-2007 08:13:53
Hy TRAN ONLY . And ya may as well get 4 five gallon buckets and while your at it drain and refill the PTO and the hdy. There is a small plug on the left side of the transmission about a third of the way up from bottom that is the fill level . The PTO has it's owen drain and fill plug.
sd pete
11-05-2007 07:01:54
It should have ihc hytran or similar. Do not put 90 wt in it
Nat 2
11-05-2007 06:22:16
 Re: 450 Gear case oil in reply to old, 11-05-2007 04:31:51
Anything labeled "Gear Lube" and as much as it takes until it starts to run out the level plug in the left side of the transmission casting. I seem to remember a figure of 17 gallons for an M.
