paint codes - CNKS
superih
11-06-2007 05:30:28
I was reading your thread below on Red paint numbers and codes. Do you have info on the white IH number, PPG paint code, and the years it was used. I purchased Harvestor white and it was alot whiter than I wanted, I was looking for the Cream that IH used.
Thanks
Mark Peters
11-06-2007 13:46:17
 Re: paint codes - CNKS in reply to superih, 11-06-2007 05:30:28
IH used #901 white on their tractors from 1956 thru about 1970 or so.The PPG code is 8665. I`ll try and post a link for you also.Mark
http://www.ihcubcadet.com/IHCCFAQ/Paint.htm
superbn
11-06-2007 10:42:22
I can't seem to figure this out either I think that 902 and 935 are the two versions of the whitecap white that was used between 1957-65 the cream was used between 1940-42 but i can't find a PPG or Dupont paint code.
http://www.ihcolor.com/
El Toro
11-06-2007 07:18:59
Here's the PPG codes for IH-902 white is 90592, for IH-935 the code is 91607. You may want to look at at a paint chip on this paint code 23056 for cream. Hal
superih
11-06-2007 09:05:50
 Re: paint codes - CNKS in reply to El Toro, 11-06-2007 07:18:59
What is the difference between 902 and 935?
El Toro
11-06-2007 11:21:31
 Re: paint codes - CNKS in reply to superih, 11-06-2007 09:05:50
It only says white on both paint codes. I would look at the paint chips to see if there'e difference. Hal
