magnetos on farmall h
mark3006
11-06-2007 08:30:17
i need a new mag its a 6 volt stystem,do i need to put standard mag back in it or is there options for what i can do here.
El Toro
11-06-2007 12:50:27
 Re: magnetos on farmall h in reply to mark3006, 11-06-2007 08:30:17
third party image
Here's the conversion that Old mentioned to a distributor. Hal
old
11-06-2007 09:51:19
You can go with a mag and or distubutor either one will work just fine. You can also do a little trick to the mag you have and turn it into a distubutor just by wireing up a coil and hooking it into the mag so the mag points operate like a distubutor does
RustyFarmall
11-06-2007 09:28:18
Try this guy. He'll fix you right up.
RustyFarmall
11-06-2007 09:22:36
 Re: magnetos on farmall h in reply to Red Dave, 11-06-2007 08:44:35
And for what it's worth, a magneto does not care if the battery is 6 volt, or 12, because a magneto makes its own electricity. A battery is not even needed.
mark3006
11-06-2007 09:29:41
 Re: magnetos on farmall h in reply to RustyFarmall, 11-06-2007 09:22:36
thanks for the comment, is there more than 1 kind of mag for this application.
RustyFarmall
11-06-2007 13:34:50
 Re: magnetos on farmall h in reply to mark3006, 11-06-2007 09:29:41
There are several that could be made to work, but the IH H-4 mag is the only one that will be correct, and will be much easier to find than anything else simply because there were so many of them made. Most of them are still out there somewhere. I think I have at least 4 dead ones laying out in my shop.
