Belt Pully on IH 140
davida
11-06-2007 10:09:12
Can someone tell me if the ratio of the belt pully and the PTO shaft is 1:1 or does the belt pulley turn faster?
I took the belt pulley off of my 140 and put the cover in its place, the bearings went bad and I really don't need it any more.
I am asking because I have a belt driven corn sheller I would like to sell. The pulley on the corn sheller is the same diameter as the pulley on the 140. If the ratios are 1:1 then I might put a PTO shaft on it before I sell the corn sheller, be easer to sell. If the belt pulley turns faster then the pto shaft, 540 rpm's then I will leave it as is.
Thanks for any help, I could remove the cover on the tractor and look at the gears and figure this out but I thought I would ask first.
n9lhm
11-06-2007 18:09:09
 Re: Belt Pully on IH 140 in reply to davida, 11-06-2007 10:09:12
Davida, if you would like to part with that pulley gearbox I might be interested. E-mail is open. Thanks, Brian
davida
11-07-2007 07:37:58
 Re: Belt Pully on IH 140 in reply to n9lhm, 11-06-2007 18:09:09
Going to keep it. I have it all taken apart, bearings cleaned up and put up to replace one day. The rest is still in a bucket covered in oil. I don't have a use for it but that might change one day. The 2 bearings and 1 seal will not cost much, I hope, just a matter of having a need, more than likely I will just get the parts, fix it and put it back on.
I cannot stand to have something that does not work. It runs me crazy to have something and it not work, this also runs my wife crazy since I am always fixing something.
Hugh MacKay
11-06-2007 11:30:20
David: scotty is right, belt pulley shaft bit more than twice the speed of pto shaft.
scotty
11-06-2007 11:06:27
Afternoon David, I believe the belt pulley RPM at PTO speed is 1157 RPM.
scotty
davida
11-06-2007 13:17:35
 Re: Belt Pully on IH 140 in reply to scotty, 11-06-2007 11:06:27
Thanks, I was thinking it was twice the speed or more but could not remember for sure.
