belly pump seal #
1951farmallh
11-06-2007 17:14:21
anybody know which seal on this site is for the belly pump drive shaft on an H? I need the one coming from the rear end connecting to the pump, the one that goes around the shaft. Is it the seal designated "Oil Seal: countershaft"? thanks for your help.
john *.?-!.* cub owner
11-06-2007 19:17:31
 Re: belly pump seal # in reply to ggg7lazy77, 11-06-2007 17:14:21
just give NAPA the IH part number, they can cross it over.
1951farmallh
11-06-2007 18:22:04
 Re: belly pump seal # in reply to 1951farmallh, 11-06-2007 17:14:21
ok, well i got the Case IH part number...but the nearest dealer is like 50 miles away... Is there a part # for NAPA? this is the lift-all seal.
Thanks.
Janicholson
11-06-2007 17:40:43
The countershaft seal is on the trans casting (toward the back of the tractor). The pump seal is in the lift all pump. caseih.com has the diagram. follow the directions to parts. JimN
kfox
11-07-2007 04:23:44
 Re: belly pump seal # in reply to Janicholson, 11-06-2007 17:40:43
The seal # for the liftall pump is CR13649
The seal for the transmission is CR13602 ( I have a note in my parts book that says 2 seals required) Probably because the coupling nut had groves worn in it. ken
