1955 Farmall 200
dracosloe
11-06-2007 20:07:51
I have a farmall 200 that I have been having a heck of a time getting going, I have only worked with masseys and allis chalmers, but they were all 12 volt systems, can anyone tell me the difference in negative ground and positive ground, everything i have had has been the same as a car, any help would be much appreciated, thanks in advance...Mike
gene bender
11-07-2007 01:58:29
 Re: 1955 Farmall 200 in reply to dracosloe, 11-06-2007 20:07:51
Some regulators will say on the bottom either pos gnd or neg gnd but the tractor when new was pos gnd as the gen doesent care just polarize it before running or you can burn the reg
Andy Motteberg
11-06-2007 20:12:55
I think it should be positive ground.
dracosloe
11-06-2007 20:41:35
 Re: 1955 Farmall 200 in reply to Andy Motteberg, 11-06-2007 20:12:55
how do i tell if its positive or negative? this tractor came mostly in pieces as far as electronics..... sorry but trying to learn as i go on this one
thank you for your time
mike
Janicholson
11-07-2007 06:43:12
 Re: 1955 Farmall 200 in reply to dracosloe, 11-06-2007 20:41:35
From the factory, it was positive ground 6v. Look to the archives here (Search For) to find a thousand hits on the topic. John T input is particularly useful. JimN
