will it fit
olderguy
11-07-2007 11:36:19
Need to know if a complete 2 point system off a 460 will fit a 560.
Wardner
11-07-2007 14:48:47
 Re: will it fit in reply to olderguy, 11-07-2007 11:36:19
Most of the parts are the same. 560 is around two inches wider and requires different brackets that attach the hitch to the sides of rear frame. The bracket underneath the transmission is also different.
Call Mike at Steel Wheel Ranch. He might sell the brackets.
Hugh MacKay
11-07-2007 16:09:15
 Re: will it fit in reply to Wardner, 11-07-2007 14:48:47
Wardner: I think the 560 rockshaft is also longer, actual shaft not the rockshaft lift arms.
Wardner
11-07-2007 17:59:14
 Re: will it fit in reply to Hugh MacKay, 11-07-2007 16:09:15
Geez, Hugh, you had to make me look it up, didn't ya? Although I don't own a 460, I keep a 460 parts book so that I can check parts interchangeability with other contemporary IH tractors.
Quite simply, you lose on this one. 523 095 R93 for cable type systems and 374 916 R91 for linkage type systems are used as rockshafts on both Farmall 460 and 560. I knew it had to be. It's the IH way of doing things. The previously mentioned side brackets for each model were formed to accept a common rockshaft.
So there.
Hugh MacKay
11-08-2007 04:54:02
 Re: will it fit in reply to Wardner, 11-07-2007 17:59:14
Wardner: My appologies, I'll not argue with the parts book. Just figured that shaft would match the width.
Hugh MacKay
11-07-2007 12:14:59
No, the chassis are different width. 560 is wider.
