T/A clutch release bearing
Todd in NC
11-07-2007 15:52:16
Well I got the T/A clutch out of the 350 Utility. Now I need the release bearing, but don"t know how to get the old one off the sleeve. Does anyone have any suggestions on how to do this. I can"t figure out a way to hold it while trying to man handle it. Any help would be appreciated. Thanks, Todd.
Owen Aaland
11-08-2007 07:15:46
 Re: T/A clutch release bearing in reply to Todd in NC, 11-07-2007 15:52:16
There should be two small holes in the back side of the carrier that you can use to drive the bearing off with a punch.
Joe Evans
11-08-2007 05:21:30
Roger46 is correct.
ih560
11-07-2007 19:25:10
 Re: T/A clutch release bearing in reply to Mike CA, 11-07-2007 15:52:16
I just put the bearing itself in a vice, and then used a screwdriver to pry the carrier off of it.
Roger46
11-07-2007 19:10:56
Todd, They are not really pressed on that hard. I just took mine off a few weeks ago and I did it by just banging it down on two blocks of wood so the bearing strattles the blocks. Or you can drive it out with a punch through the inside since you are putting in a new one you don't have to worry about ruining the old one. Roger
Janicholson
11-07-2007 16:28:52
I think a bearing splitter, a hydraulic press, and a piece of round stock to match the sleeve to push with. Best of my memory. JimN
