IH 350 Fast hitch hydraulics
TomA
11-08-2007 13:42:46
I finally got the 350 I bought running and the Fast hitch and power steering do not work. I checked the fluid and it was low and had water in it. I drained it and I plan to pull the cover and check the screen and whatever else is inside. The manual says to use IH Fast Hitch fluid. Can't I use regular hydraulic oil?
Nat 2
11-09-2007 05:11:15
 Re: IH 350 Fast hitch hydraulics in reply to farmerweber in PA, 11-08-2007 13:42:46
Most walmarts have two types of hydrailuc fluid. One is thaat ISO1284 stuff that claims to meet Hytran specs. The other is the "R&O" type.
Rootsy
11-09-2007 04:48:21
 Re: IH 350 Fast hitch hydraulics in reply to Cris, 11-08-2007 13:42:46
TomA said: (quoted from post at 19:29:01 11/08/07) Thanks Evan, I'll stop at WallyWorld on my way up to the ranch tomite and pick some up.
Tom
I doubt you'll find hy-tran at wally world...
georgeky
11-09-2007 09:39:18
 Re: IH 350 Fast hitch hydraulics in reply to Rootsy, 11-09-2007 04:48:21
Yea, they sell equivilent there. Hey did you ever determine the model of that corn planter? I think it is a 245.
r4etired
11-08-2007 18:02:37
 Re: IH 350 Fast hitch hydraulics in reply to TomA, 11-08-2007 13:42:46
I had a hard time getting a customers to prime I took the suction hose loose at the pump and primed it Finaly it took and worked fine since.
Evan350
11-08-2007 13:49:50
You can use Case-IH "Hy-Tran", or a generic brand of hydraulic oil that says it meets Hy-Tran spec.
TomA
11-08-2007 18:29:01
 Re: IH 350 Fast hitch hydraulics in reply to Evan350, 11-08-2007 13:49:50
Tom
Evan350
11-08-2007 13:51:47
P.S. While you are at it, clean and inspect the breather which is a mushroom-shaped thing on top of the reservoir.
