Problem w/ Lift-All pump on H
Illinois Farmal
11-09-2007 12:10:33
I have a "46 H with a Lift-All belly pump that has recently started giving me problems. I"m using a Stan Hoist trip bucket loader on it and when I have even a small load on it, it doesn"t want to lower smoothly. The push rod acts like it has a lot of pressure against it and when you go to lower it, it just drops like a rock when it does release. When the bucket is empty it lowers fine. I"ve used this loader for several years with no problems before....what could be causing this??? Thanks to all in advance.
Janicholson
11-10-2007 06:26:22
 Re: Problem w/ Lift-All pump on H in reply to Illinois Farmall, 11-09-2007 12:10:33
When Liftalls get into the prime of life (working well, but many hours)the release of the lever seems to be jerky under high load. Two solutions come to mind but are not tested. One easy, one hard.
EASY: stiffen up the rod controlling the lever. The rod flexes enough to allow springing in the length of the rod and this seems to be a marginal way to be delicate in control the lever. It is ugly, but a test of the idea might be to use a Vicegrip and "clamp" a 1/2" diameter rod near the lever end of the regular control rod and use that to "parallel" the normal rod to see if better control results from a stiffer rod.
HARD: within the Liftall there is a spool valve the lip on the spool that closes off the return of fluid to the resevoir could be modified with a Dremel grinder on one edge to allow valve movement to open a smaller channel as it begins to relieve pressure. Unless you are pretty sure of what you are doing with spool valves/hydraulics, this might be a bad idea. (consulting a good older hydraulic expert to assist might be good as well)
JimN
glennster
11-09-2007 16:20:40
there may be a check valve on the loader that is stuck open. there is a valve available that will allow full flow one way on hydraulics and limit the return flow so the implement doesnt drop. it could be located where the hydraulic line hooks to the elbow at the all pump on the tractor, or at the end of the line where it hooks to the loader cylinder.it should be about the size of a pioneer female hydraulic coupling, maybe a little bigger. there is a check ball inside that limits flow. maybe dirt or something is blocking the check ball.
