560 Farmall, Diesel,Factory Turbo
Mel Pulskamp
11-09-2007 14:16:23
Help-Need price and information on 560 Diesel w/ Factory Turbo,Tele-depth, Two point, narrow front,Better than average condition.Can anyone help with the value of this tractor. Also where can I find the production numbers on how many were built.The serial number tag is on the tractor, can get this number.
Ph.# 812-498-9536
ChrisAS
11-10-2007 08:10:57
 Re: 560 Farmall, Diesel,Factory Turbo in reply to Mel Pulskamp, 11-09-2007 14:16:23
Mel IH did have an after market tubo kit with 660 oil bath air cleener for the 560. Only thing had to cut different hole in hood for the stack. Other than that would not it was on there.
uncle rob
11-09-2007 15:13:11
The tractor actually belongs to Rob.It is a Garrett turbo and the air cleaner system is much like that of a 656 and inserts into the side.
Hugh MacKay
11-09-2007 14:51:51
Mel: None of them were turbo from the factory, that leaves roughly 65,000 - 560s that came off the assembly line naturally aspired. My 560 was one of the last and one year later IH had no turbo for it, only option I saw at that time was M&W. I still have that piece of M&W literature my IH dealer gave me.
bradd
11-10-2007 17:26:45
 Re: 560 Farmall, Diesel,Factory Turbo in reply to Hugh MacKay, 11-09-2007 14:51:51
have a old ih recall/field change book that has a change on a turbo part for a 560 with what ih called a dt282. i would say for it to be called a dt282 it would have to be factory option and not an add on. it has ih part numbers for the recalled/changed parts.
Hugh MacKay
11-10-2007 18:06:29
 Re: 560 Farmall, Diesel,Factory Turbo in reply to bradd, 11-10-2007 17:26:45
bradd: DT282 is right but it was never used on farm tractors from the factory. Any factory DT282 I've seen also had an inline injection pump and were used as stationary engines or industrial equipment. There was never a Farmall 560 from the factory with turbo, you could not even buy an add on IH turbo in early 1964. I tried.
Allan In NE
11-09-2007 14:47:47
You sure that engine didn't come out of a crawler? Just don't think the 560s came with a turbo.
That narrow front kind of knocks it in the head, but the right guy might get up there around 5 depending on condition?
Allan
Hugh MacKay
11-10-2007 03:28:19
 Re: 560 Farmall, Diesel,Factory Turbo in reply to Allan In NE, 11-09-2007 14:47:47
Allan: You probably know the answer but didn't those same crawlers all use a different injection pump than the farm tractors? All that I've seen around these parts crawlers have inline injection pumps while the farm tractor had Rossa Master.
I've only been close up on 1 TD9 and it would have been a mid to late 60s model with 282, turbo and inline injection pump. I've noticed the inline injection pump on other crawlers but never looked them over closely, as it applies to engine or turbo.
randy hall
11-09-2007 14:54:05
ih had a turbo for the 560 in the high altitude areas like colorado.
1206SWMO
11-09-2007 18:27:59
 Re: 560 Farmall, Diesel,Factory Turbo in reply to randy hall, 11-09-2007 14:54:05
You are correct.There used to be a 560 turbo about 40 miles from me that was tractor pulled with in the early 1970's.It had the air cleaner mounted on the hood.It was dealer installed but was a factory kit.
Harold H
11-09-2007 15:38:14
The turbo was offered in high altitude areas only. However I believe it was a dealer installed option, offered only to dealers in that area, rather than factory installed.
Harold H
Seeing Red
11-09-2007 18:39:36
 Re: 560 Farmall, Diesel,Factory Turbo in reply to Harold H, 11-09-2007 15:38:14
We are in Michigan and we had a turbo installed on our 560D by our then local dealer.It was an M&W unit. There was another one just 1/2 mile away from us as well. Those were the only two I ever saw locally. It made a nice add-on for the 560, but it also came with a lot of head bolt breaking problems too.
wgatewood
11-09-2007 18:23:51
hugh, sumed it up correctly
