Farmall H Loader Pins
Martin Miller
11-10-2007 16:10:26
I have a set of pins that I took off from my loader for a Farmall H. I would like to know if these are still available or if anyone has a set that are better than mine. They are very badly worn. Any help would be appreciated. Thanks. Pics attached.
Janicholson
11-11-2007 16:01:58
 Re: Farmall H Loader Pins in reply to Martin Miller, 11-10-2007 16:10:26
Reaming the holes to a next size is probably a good Idea. The pins can be cut from medium carbon stock bar at a metal supply firm. JimN
mkirsch
11-10-2007 19:27:45
 Re: Farmall H Loader Pins in reply to Nebraska Cowman, 11-10-2007 16:10:26
Martin,
There are dozens of different loaders that fit a Farmall H, and many more that have been modified to fit. You'll need to be more specific.
They may be standard parts. All they really are, are hardened round bar.
If the pins are worn, so are the bushings. New pins, even if available, may not take out enough of the slop. You may want to get oversize pins made at a machine shop.
Wisconsin Cowman
11-10-2007 17:05:56
Get a a pair made up.
