504 power steering question
Warren R.
11-12-2007 17:28:02
I have a 1964 504 utility gas tractor with only 1600 hours on it. It has had an easy life.The power steering works well except it seems to move with a fair amount of resistance of the steering wheel. It is a bit difficult to turn the steering wheel very fast. It does not have a loader on it, nor did it ever have one on it. It does give a light chatter in the steering wheel when I turn it to the left, but it never stops turning. Is there something I can do to make the steering wheel turn with less resistance? Or is there something wrong someplace in the system. Thank you.
the tractor vet
11-12-2007 20:25:46
 Re: 504 power steering question in reply to Warren R., 11-12-2007 17:28:02
You will need to have the flow rate of the pump checked and also flow and pressure to the steering . This will have to be done with a flow rater . This will save time and money tryen to find the problem . Might be a bad pump , might be a bad flow divider , pressure regulator may be a bad hand pump .
