Electrical/Ignition System C - question
Harrell Rumfiel
11-13-2007 07:47:50
I have replaced all parts of the electrical/ignition system on my 1938 C. I have the full 6v current to the positive side of the coil, but I can't get a spark from the secondary coil wire - it only reads about 2v at the coil. Points are good, new everything. What's the problem with current to the coil, but none out?
Janicholson
11-13-2007 09:33:35
 Re: Electrical/Ignition System C - question in reply to Harrell Rumfield, 11-13-2007 07:47:50
I am going to add that the insulator that keeps the bolt going through the distributor housing can get out of place and ground to the housing causing your symptoms. If you turn the engine till the points are open, and the voltage on the wire going to the points is still very low (it should be bat voltags)then check this insulator, or the point spring connected under it instead of on it.
On a positive ground vehicle (stock setup on yours) the positive is connected to the distributor, not the ignition switch. It does make a difference, but it will run either way. JimN
John T
11-13-2007 08:49:12
Harrell, SHORT ANSWER FIRST
The voltage on the coils high input (NOT to distributor) terminal should read near full battery voltage when the ignition is switched on, of course. If the switch is bad it may drop voltage in which case there would be less then full battery voltage assuming the points are good n are closed. If the switch is bad try to hot wire the coil n by pass the switch. However, over on its other to distributor terminal it should read near 0 volts when the points are closed but again near batetry voltage when open (unless the coils primary is bad/open) . If you put a 6/12 volt test lamp on the coils low (to distributor) terminal n crank the engine over the lamp should flash ON (when points are open) n OFF (when points closed). The coil should be conducting something like 3 to 4 amps when the points are closed and its output voltage drops to near 0 also when they are closed as thats basically grounded out via closed points. For the coil to fire it has to first conduct current through it from its + to - via closed points but then when they open and that current is interrupted, she fires high voltage out its top HV secondary tower.
As Carl (Billy Bob Thornton) said in the Movie Sling Blade,,,,, when she dont fire "Its probably the points" see below, maybe they or the condensor is bad or wired wrong or grounded out somewhere..... ....
LONG ANSWER
Since non sparking can be caused by a lot of things heres my Troubleshooting Procedure, some of which repeats the above in more detail.
TROUBLESHOOTING A BATTERY POWERED EXTERNAL COIL TYPE IGNITION SYSTEM:
PRELIMINARY CHECKS:
(A) To see if it happens to be a cap n rotor problem and to see if at least the coil is firing, remove the coil wire from the distributor (leave coil end intact) and place its bare end to within 1/8 inch from tractor iron, turn her on n crank her over, and see if she jumps that gap with a good visible blue spark????? If so but the plug wire ends (from wire end to 1/8 inch to frame) or the plugs themselves don’t fire, its a cap n rotor or plug wire problem. If the coil wire isnt even sparking, see below.
(B) Next open the cap and see that the points are gapped correct and indeed opening and closing as the engine is cranked and the distributor shaft rotates and MAKE SURE THEY ARE NOT BURNED OR PITTED OR CARBONED UP BADLY !!!!! !!!!! If so, running a point file between them to clean them up might make her run again HOWEVER that’s only a temporary cure, so if that cleaning makes her spark, INSTALL N GAP NEW POINTS. In the event they appear good but only gray oxide coated, non abrasively clean/buff/polish them using say a dollar bill or shop cloth etc. and see what happens.
MORE TROUBLESHOOTING IF ALL THE ABOVE STILL FAILS TO MAKE HER SPARK
1) THE VERY FIRST THING YOU GOTTA HAVE is voltage to be present on the coils high supply (NOT to distributor) terminal when you turn the Ignition switch ON. If not she cant ever fire, but in the event the ignition switch or circuit/wire down to the coil or any Ballast Resistor is bad or open, you can HOT WIRE it by jumping a hot ungrounded battery voltage source to the coils high input supply (NOT to distributor) side n see if she runs then???? If she fires hot wired, you could have a bad ignition switch ((That can happen, when Ignition is on, the switches IGN terminal must turn hot)),,,,, ,or an open Ballast (if it has one) or a bad/open wire from switch to coil.
If the switch is good, if you turn the ignition switch on and place a test lamp on the coils high (NOT to distributor) terminal SHE MUST LIGHT UP. If not again, look for an open Ballast Resistor (if it has one, it should read around 1.25 to 2 ohms across its terminals) or bad/open wires from the switches IGN output down to the Ballast (if it has one) and distributor.
2a) When the Ignition switch is turned on, voltage should appear on the coils high input side. That would be 6 volts on a straight 6 volt system or 12 volts on a 12 volt non external ballasted system, or around 6 volts on a 12 volt system that used a 6 volt coil plus an external Ballast Resistor and the coil is good and the points are closed and they and ALL wiring is good.
2b) To insure the coils low voltage primary winding is not bad/open, use an ohmmeter and measure its DC resistance between its lil + and -terminals. If its an open circuit (no continuity) its bad/open and will NOT work. It should measure around 1.25 to 2 ohms or so if its a 6 volt coil and maybe 2.5 to 3.5 if its a 12 volt internally ballasted coil. NOTE CAUTION have all leads and any voltage source DISCONNECTED FROM the coil for this simple primary winding continuity test. 3) Next, place your voltmeter or test lamp over on the coils other low to distributor terminal side, turn her on and crank the engine over.
4) A test lamp there should flash ON (when points are open) and OFF (when points are closed) as the engine is cranked slowly.
5a) If the lamp never comes on there, the coils primary is bad/open,,,,, ,,,,or the points are never opening,,,,, ,,,or theres a shorted/bad condensor (remove its lead to points and see if lamp comes on, if so, bad shorted condensor or its wiring),,,,, ,,or the points wire is shorted,,,,, ,,or the distributors side pass thru stud is grounded (use ohm meter to test that),,,,, ,,,or the points may have a shorted spring.
5b) If the lamp never goes off as engines cranked, the points are not closing or are bad,,,,, ,,or the wire or circuit is missing from the distributor to the points,,,,,or the distributors not well grounded to the tractor.
She cant fire the coil unless its low side is getting a conductive ground return path via closed points and then the circuit is open when the points open.
Be sure the condensor or its wiring is NOT shorted out and see if the lite comes on (when points open) with the condensor disconnected. If removing the condensor makes her spark, replace the condensor.
SUMMARY
Be sure the points are closing fully and open on high cam and ARE NOT BURNED OR PITTED OR CARBONED UP BADLY,,,,, ,theres voltage present on distributors high side at all times when ignitions on (or its a bad switch or open ballast or bad wiring to col),,,,, ,voltage on coils low side flashes on and off as distributor is cranked,,,,, ,,,condensors not bad/shorted,,,,, ,,no shorts in wires to points and no shorts in pass thru side out distributor stud,,,,, ,,coil has continuituy.
You may luck out n just need a new set of points. If the coil wire fires (see above) and the plug wire ends to 1/8 from frame but NOT the plugs, they are baddddd ddddd . Check them BOTH.
Good Luck n God Bless, post back any questions and your findings and any questions.
John T Nordhoff in Indiana, retired electrical engineer who usually lurks over on the Mother Deere boards versus over here on the “dark side”.
El Toro
11-13-2007 08:02:24
I think your C is a 1948. That was the first year for them we had a 1950 C. Hal
Brownie450
11-13-2007 08:01:27
Sorry about stepping on your toes, Hal.
El Toro
11-13-2007 08:04:04
 Re: Electrical/Ignition System C - question in reply to Brownie450, 11-13-2007 08:01:27
You must have stepped lightly since I didn't feel it. Hal
Brownie450
11-13-2007 07:59:37
If it is original--6volt positive ground--the + on the coil should be connected to the distributor. The wire from the ignition switch should be connected to the coil negative terminal.
El Toro
11-13-2007 07:59:13
You need the points closed to have voltage on both small terminals on the coil. The wire from the plus terminal on the coil should go to the distributor if your battery is plus grounded. Take a cotton swab dipped in alcohol and clean those new points. Make sure they're gapped at .020". Hal
PS: Pull the coil wire from cap and hold within 1/4" of good ground and make an attempt to start the tractor with ignition switch on. Should get a hot spark when cranking. You will need a helper.
