1940 H pistons and head nuts
tackhammertime
11-14-2007 08:34:31
I have my H head off being reworked and it has step head pistons in it. A fellow told me that only flat head pistons come in 1940 H C152 engines. Also all the head bolt nuts were 3/4" but one it was 11/16" is this common? The fellow I got it from hia family bought this tractor new and he said no one had ever gone into the engine before. Water pump was all they had ever replaced.
skk-big red fan
11-15-2007 18:43:15
 Re: 1940 H pistons and head nuts in reply to tackhammertime, 11-14-2007 08:34:31
Are the pistons cast iron or aluminum?? That will tell us.
44 massey
11-14-2007 12:30:01
I should have some extras of the head bolt nuts. Contact me if you need a couple and will send!!
RustyFarmall
11-14-2007 10:38:14
The larger nuts are "heavy duty", and are what is supposed to be there. The smaller one is a common ordinary "hardware store" style, and is not correct. You will not find the heavy duty nuts at any hardware store, farm supply store, Lowe's or Home Depot. You will have to get them at a machinery dealer, or from McMaster-Carr or similar. Fastenal might have them.
El Toro
11-14-2007 10:32:22
Piston rings weren't that great back in the 1940's
so I doubt the story of not having a rebuild. My brother and I bought a new 1949 Dodge Coronet and it drank oil. Even when new. A new set of rings
installed in 1953 and that cured the oil burning.
I drove it to Florida in 1955 just before I was I was discharged from the Army. I then pulled a mobile home from Ft Bragg NC to MD when I was discharged. Still didn't use oil. Hal
NDS
11-14-2007 09:32:09
Unless the person who told you H had never had engine work has been around tractor all of these 67 years I would not put much stock in his story that engine has never had work. We used our H for full time farming back in fortys and 3 or 4 years was about life of engine and our nieghbors tractors were about the same.
tackhammertime
11-14-2007 10:04:09
 Re: 1940 H pistons and head nuts in reply to NDS, 11-14-2007 09:32:09
Your on the same page as I am Grandson of the guy who bought it and his father are who my info came from. I am having a hard time with farming 10K acres and no rebuilds.
Mike CA
11-14-2007 08:47:32
What is the serial number of the H? Does it have an X code after the serial number?
IIRC, step heads were used for higher compression for higher altitude engines. The codes will tell us.
tackhammertime
11-14-2007 09:02:38
 Re: 1940 H pistons and head nuts in reply to Mike CA, 11-14-2007 08:47:32
FBH 24108 both numbers match. This tractor was bought new in Oklahoma.
edward_m
11-14-2007 09:34:00
 Re: 1940 H pistons and head nuts in reply to tackhammertime, 11-14-2007 09:02:38
I've got a '40 also...I'm assuming yours is a distalate model like mine (no letters after the serial). IIRC, when I had the head off of mine years ago, they were flat head pistons.
Your's sure does sound like its got the 'altitude' option. They were either 5000 ft. or 8000 ft. pistons and cylinder sleeves, available as an option on distillate or high-compression engines.
Unfortunately, the codes might not tell you anything: you could get them as a 'special attachment', dealer installed, as well as factory ordered on the tractor.
So you might not find any special marks or letters if the dealer installed them.
All my head bolts were the same, so I can't help on the nut question.
tackhammertime
11-14-2007 09:58:01
 Re: 1940 H pistons and head nuts in reply to edward_m, 11-14-2007 09:34:00
tread size is all the same OD is different on the nut.
RyaninKS
11-14-2007 10:22:07
 Re: 1940 H pistons and head nuts in reply to tackhammertime, 11-14-2007 09:58:01
my 46 M was had the 1 different size nut also...idk maybe a factory goof?
glennster
11-14-2007 10:21:18
if its hjust the ouside measurement on the nut, it was replaced somewhere along the line. i bought some new studs and nuts for an m and the nut size was smaller than the origionals
