1466 Oil Seals
61-4010
11-14-2007 16:48:31
Hey all. I bought a 1466 Turbo about a year ago and the rear seal on the motor clearly needs to be replaced (along with several other gaskets and such). Realizing that it will require a split and removal of the clutch assembly, can the seal be replaced while the engine is in frame? And what about the front?
Thanks for any advice.
K.B.-826
11-14-2007 19:35:00
 Re: 1466 Oil Seals in reply to 61-4010, 11-14-2007 16:48:31
Yes, both can be done in frame. While you've got it split, you'll want to pull the trans input shaft/live power shaft assembley out of the clutch housing, as they'll at least need new seals and bearings, and the splines that mesh with the clutch disc and pressure plate are often shot on these bigger IH's.
