Farmall F 20 overdrive
Will Sick
11-14-2007 17:33:21
I was wondering if someone could tell me how much is involved with the add on overdrive or road gear for an F20 Farmall. Do you need to make changes in the transmission or is it all contained in the box that mounts on the front.
cole in mo.
11-14-2007 17:52:04
 Re: Farmall F 20 overdrive in reply to Will Sick, 11-14-2007 17:33:21
Nothing hasta be changed in the trans, it bolts on the front and is easy to do, but if you're talking about a heisler over drive, one that gives you 8 speeds forward you gotta move the engine and radiator forward to get it in, then slide it back to the orig. place.
