calling mike ca !!!!!
glennster
11-16-2007 06:03:57
mike, i'm working on your lower grille bar for your h. was yours cut straight down on the sides like this one?? i am going to make the sides a little long so you can trim them to fit.
third party image
Mike CA
11-16-2007 20:12:36
 Re: calling mike ca !!!!! in reply to glennster, 11-16-2007 06:03:57
Glenn, below is a picture of the bottom of my grill. As you can see, it was cut away much like yours. So the replacement should work fine.
Thanks again! I really appreciate it. And the $1500 you asked for will be in the mail soon. third party image:lol:
third party image
glennster
11-16-2007 09:31:50
mike - emaile me your address, parts all done-here ya go. you;ll need to tweek it a little when you weld it in, i put the tabs on the bottom and the sides, and i left some extra metal on the side tabs so if you need to fold the second step you have enough metal. i fitted it up to my hood and it will work good. little welding, little bodywork, good to go. mig weld it in!!!
third party image
Tom Windsor
11-16-2007 20:27:54
 Re: calling mike ca !!!!! in reply to glennster, 11-16-2007 09:31:50
You do good work.
tw
