Oil for Farmall H
Ron Bledsoe
11-16-2007 08:28:08
I have recently acquired a Farmall H and I do not know it's history. Shows good oil pressure, 60 psi, but does smoke a little from time to time. I suspect that maybe the valve guides are bad and do plan on a valve job soon. Does anyone have any suggeations on oil viscosity? We use Mystic brand in all our tractors and vehicles.
Mike CA
11-16-2007 20:23:39
 Re: Oil for Farmall H in reply to Ron Bledsoe, 11-16-2007 08:28:08
Tom Windor said: If you do not know the tractor, it would be good to pull the pan and clean the sludge out of it before running HD oil.
TW
Done. I actually had to get a "new" pan, which was in pretty messy shape, but a lot straighter than the original pan. I cleaned it out very well. Under the valve cover was very clean as well.
Tom Windor
11-16-2007 20:24:24
TW
Danto
11-16-2007 20:28:18
 Re: Oil for Farmall H in reply to Tom Windor, 11-16-2007 20:24:24
Maybe a dumb question, but what is HD oil?
Tom Windsor
11-16-2007 20:37:15
 Re: Oil for Farmall H in reply to Danto, 11-16-2007 20:28:18
High Detergent. I got one that has been using 30 W non detergent oil. I put HD oil in it and it broke the sludge loose and sucked it into the oil pickup...and i lost oil pressure...and I never noticed till it locked up.
tw
Danto
11-16-2007 20:51:37
 Re: Oil for Farmall H in reply to Tom Windsor, 11-16-2007 20:37:15
Tom,
Thanks, that is good to know. dan
Mike CA
11-16-2007 19:49:17
I have two gallons of 15w 40 sitting on my tool bench ready to go. That what was recommended by several members of this board.
I'm not sure what viscosity came out of it. What viscosity is sludge?
RustyFarmall
11-17-2007 06:23:00
 Re: Oil for Farmall H in reply to Mike CA, 11-16-2007 19:49:17
Mike, the 15w-40 will be just fine, but remember that you need only 6 quarts.
Andy Motteberg
11-16-2007 17:31:59
I use Harvest King all season in my H.
edward_m
11-16-2007 09:44:21
I've had a '40 H since the mid '80s, always used 30W, never had any problems. I live in Iowa, and the only thing you notice is that at -20, its a little stiff to start, but I always warm a tractor before using it.
If you follow IH suggestions, they claim that during the winter, use a lighter weight such as 20W, or a multi-grade like 10W30.
DickelDawg
11-16-2007 08:34:32
I've had a 1950 Farmall H for 7 or 8 years and I use 10W-30 in it. It doesn't smoke and runs very good. The grade of engine oil will definitely depend on where you live and how you use the tractor though. I live in NorthWestern Colorado and use the tractor for plowing snow and other misc. tasks. Not hard usage. I'm basically just a putterer.
Wisconsin Cowman
11-16-2007 08:29:53
A good 15w40 would be fine or just 30wt too.
