engine knock
Big Pete
11-16-2007 19:47:50
I have a farmall cub that I restored 2 years ago.Did not do anything to the engine because it ran like a swiss watch,did not smoke,had good oil pressure.it sat for over a year now has a knock and no oil pressure.oil level is on full mark. Before i start terrying things apart,anyone have any suggestions?Thanks
Big Pete
11-17-2007 10:44:06
 Re: engine knock in reply to Big Pete, 11-16-2007 19:47:50
Thank you gentlemen for all the good advice.Thought it had something to do with the oil pump, but did not know it could loose it's prime.Will try that and see what happens.
billde
11-17-2007 18:33:41
 Re: engine knock in reply to Big Pete, 11-17-2007 10:44:06
Are you by chance using 10w30 oil?
billde
11-17-2007 04:39:10
Remove the oil filter, on the block side of the filter housing there is a small hole,pump oil in there until you feel resistance. Your pump is now primed.
El Toro
11-17-2007 04:07:01
There's an allenhead plug on the back left rear side of the block and remove the filter cap and fill the housing with engine oil. You may have a ruin bearing since you have a knock. You may want to drop the oil pan and look at the rod and main bearings. Hal
Janicholson
11-16-2007 21:04:29
Pull that small plug mentioned and pump oil in it with a squirt oil can and a bit of rubber hose to make it fit tight in the hole. pump till it feels different. Do not run it till you do this. JimN
Tom Windsor
11-16-2007 20:33:35
Yep...it has lost its prime. Somewhere around the oil filter is a plug that you take out and prime the oil system. I would prime it and get my oil pressure back before I started tearing anything apart.
tw
Tom Windsor
11-16-2007 20:33:34
tw
Karl Hamson
11-16-2007 22:22:56
 Re: engine knock in reply to Tom Windsor, 11-16-2007 20:33:34
I seem to have lost my prime as well. Where is that plug?? Or do I have to go to the pharmacy?
El Toro
11-17-2007 16:28:58
 Re: engine knock in reply to Karl Hamson, 11-16-2007 22:22:56
Some of those pills will make you lose your hearing and eyesight. The big Vi. Hal
dwag
11-17-2007 16:55:35
 Re: engine knock in reply to El Toro, 11-17-2007 16:28:58
HUH?
dwag
11-17-2007 14:08:48
C Allis should perk you up, ask Doctor for a sample. Warning, don't take one then go to the Mall! Like being 17 again!
jakey756
11-17-2007 04:35:58
HAHA that was good.
