Bolt torque for H?
Mike CA
11-16-2007 20:27:07
I've installed a Water Jacket Cover, and I'll be installing an oil pan this weekend. Do either one of those things require torquing the bolts?
Mike CA
11-16-2007 22:31:18
 Re: Bolt torque for H? in reply to Mike CA, 11-16-2007 20:27:07
Janicholson said: Be sure to put the long bolts in the front and rear of the pan where they came from.
I'm having to guess, since the don't list where they came from. It says there are 4 longer ones, and 16 shorter one. I'd guess the 4 longer ones go on the outside edge holes?
Janicholson
11-17-2007 07:27:52
 Re: Bolt torque for H? in reply to Mike CA, 11-16-2007 22:31:18
The longer four bolts go in the holes near the center in front and back. They screw into aluminum (If I remember correctly) and need to be there so the threads can have longer length of engagement in the softer material. The wooden block (end grain is best) is for using as an anvil to pound on while gently smoothing the tin of the pans (where the bolt holes have been deformed by over tightening) with a hammer. Please check the real torque values they should be in inch pounds, the values are less valuable than just beginning to bulge out the gasket as described. JimN
Mike CA
11-16-2007 21:16:41
Jim,
I don't understand where the block of wood comes into play. You said "flatten the edges of the block so each bolt is flat". Can you clarify what you mean, please?
Unfortunately, my pan had so many bolts of different lenghts, I don't know what is supposed to come from where. I got a bunch of original dot blots for my new pan. I'll check the IPB to see if it tells me what bolts should go where.
banjo
11-16-2007 21:37:14
 Re: Bolt torque for H? in reply to Mike CA, 11-16-2007 21:16:41
The block of wood would be for a straight edge to rest the lip of the oil pan on to flatten it so there are no peaks or valleys to leak oil.
tmonton
11-16-2007 20:54:15
The oil pan is noted at 33 foot pounds. I could not anything reference the water jacket. Just set it the same ?
Janicholson
11-16-2007 20:47:34
Flatten the edges on a block of wood so each bolt hole is flat. Put #2 nonhardening permatex (just a film, no more)on the sheet metal side on both components. Be sure to put the long bolts in the front and rear of the pan where they came from.
Tighten bolts until they are just tight enough to make everything contact without force. then tighten a little each until the gasket is seen to be squishing from tightness (a little bulge at the bolt) that is it. It is always better to be able to tighten them than it is to reflatten and replace a split gasket. JimN
Tom Windsor
11-16-2007 20:35:11
I would not be too excited about the water jacket cover but I would torque the pan bolts. I just did it and now I have forgotten the values.
tw
