1927 Regular engine manual
Tom Windsor
11-16-2007 20:31:29
I am going to commence putting the engine back together for my regular in a few days...does anyone have an overhaul manual for this engine that I can use for a while.
tw
LenNH
11-19-2007 10:39:53
 Re: 1927 Regular engine manual in reply to Tom Windsor, 11-16-2007 20:31:29
Agree it's basically similar to F-20, except for choice of mag (unless it's been replaced by an F-4 or some other more modern mag) and manifold/carb, if they haven't been replaced, too. If your governor controls are all inside, from governor housing to carb, then you have pretty much the same rig, excepting the 3-speed transmission. If the clutch is single-plate, then you're mighty close.
I don't have a Farmall manual, but I have an original manual for the 10-20 and 15-30, which are basically similar, except for dimensions (10-20 and Farmall both have the same stroke - 5", but the Farmall has 3.75" bore versus 4.25" for the 10-20). Glad to share what I have, but I haven't had much luck scanning and e-mailing small-print text, so I might have to take a few days to send photocopies by snail mail.
KevinH
11-19-2007 04:16:22
 Re: 1927 Regular engine manual in reply to Mike CA, 11-16-2007 20:31:29
Tom, if you've still got my cell phone #, call me Monday. I think I still have the overhaul manual on cd. If I can find it, I'll let you use it or something. Call me, or shoot me an email at home.
Kevin
russ hamm
11-17-2007 15:32:55
I&T has one finally for the f series, which would work. Won't cover your multiple disc clutch if you still have it, but everything should work basically like an f-20.
