serial suffix
chuck craig in
11-17-2007 10:19:21
A recent purchase of my 300 revealed aserial # of 1873 SJ. what does the SJ mean? CC
Cityboy-McCoy
11-17-2007 18:49:56
 Re: serial suffix in reply to chuck craig in SUNNY SOCA, 11-17-2007 10:19:21
D = high altitude 5,000 ft engine compression; J = Rockford clutch.
Bob
11-17-2007 10:29:58
"S" is TA with provision for 540 rpm PTI, "J" is Rockford clutch.
tmonton
11-17-2007 18:47:52
 Re: serial suffix in reply to Bob, 11-17-2007 10:29:58
That was really good !
What is the "DJ" in a Farmall H 27138DJ
D Slater
11-18-2007 04:42:29
 Re: serial suffix in reply to tmonton, 11-17-2007 18:47:52
Farmall H didn't use a suffix like that. If you are lucky maybe you have a SH with that serial # and suffix.
tmonton
11-18-2007 08:49:52
 Re: serial suffix in reply to D Slater, 11-18-2007 04:42:29
Yes sorry .. its a SH. 1954
D Slater
11-18-2007 15:06:50
 Re: serial suffix in reply to tmonton, 11-18-2007 08:49:52
In that case its what City boy posted. Engine serial # should have a D after it also. Originaly would be equiped with pistons to give a little higher compression ratio than standard altitude engine.
