Top link adjuster bar - how do I get it in?
SteveNH
11-18-2007 07:01:34
I bought a replacement cat 1 top link from the new holland dealer up the road and the small adjuster bar that goes through the center holes of top link was not installed. How do I get it in through the holes? Do I just bang it through? I feel like an idiot.
Janicholson
11-18-2007 14:08:51
 Re: Top link adjuster bar - how do I get it in? in reply to SteveNH, 11-18-2007 07:01:34
What steel did you use for the components? JimN
SteveNH
11-18-2007 15:03:19
 Re: Top link adjuster bar - how do I get it in? in reply to Janicholson, 11-18-2007 14:08:51
JimN,
For the bracket to mount the front part of the lift arm to the tractor I used 1" steel my uncle had from a cut up bridge. I bought the lift-arms new, I believe they are tempered and for the lever and the lift arm leveler are used from a worksaver kit I got new in box from someone who was cleaning out their garage for $40. From the worksaver kit I am also re-using the rock shaft bracket for the top link and the brackets that mount to where the draw bar mounts. Hugh sent me some great plans. I should be done in the next week or so. Trying to figure out which is the best weld joint on 1" steel from a welding class book.
Janicholson
11-18-2007 15:34:31
 Re: Top link adjuster bar - how do I get it in? in reply to SteveNH, 11-18-2007 15:03:19
"V" groove the weld to allow multi passes then weld it flat (makes it easy and comfortable) Make sure you chip and grind the slag out on each pass so there are no inclusions. 7014 or 7018 are nice rod. JimN
Hugh MacKay
11-18-2007 08:01:09
Steve: Now, your making me feel like an idiot. LOL How close are you to having an operating 3 point hitch?
SteveNH
11-18-2007 08:57:02
 Re: Top link adjuster bar - how do I get it in? Got it!!! in reply to Hugh MacKay, 11-18-2007 08:01:09
Thanks, I guess sometimes a big hammer will solve your problems...
Hugh,
I cut and drilled the steel for the brackets yesterday. Today I am going to prep them for welding. I am hoping by next week I will be operational. I am still waiting for my seal kit to arrive for the hydraulic pump.
Yugrotcart
11-18-2007 07:09:13
Get a nice big hammer and bang it through.
Paul
