smta fan spacer
Ray Gosnell
11-18-2007 09:43:32
When running power steering pump off of the double lower pulley the fan hits the pump pulley.where do I find fan spacer to extend fan so that it will not hit pump pulley and are there longer special fan bolts that go into water pump available?
boyd
11-18-2007 11:58:44
 Re: smta fan spacer in reply to Ray Gosnell, 11-18-2007 09:43:32
I used flat washers. worked fine. Make sure they are all the same thickness.
