1566 International V8
Chuck Brown
11-18-2007 12:41:56
Does anyone know if they made a 1566 International with a V8?
Pat-CT
11-18-2007 20:09:45
 Re: 1566 International V8 in reply to Chuck Brown, 11-18-2007 12:41:56
they have a 1468 dieseil 4 wheel drive at a farm near hear i has massive amounts of power and has dynoed at 130 hp i think something around there but they ahve moddified it i also think becuase it does 38 at three quaterthrottle ont he street great for toeing waggons they use that and there 4166 alot those are there two biggest tractors
Hugh MacKay
11-19-2007 04:31:37
 Re: 1566 International V8 in reply to Pat-CT, 11-18-2007 20:09:45
Pat: Modified, and still not great horsepower. A good many 1066 and 1466 came from the factory cranking out 150 plus.
City-Boy McCoy
11-18-2007 14:45:27
I don't know if they were right or not, but someone once told me that the last number of the tractor model in that era designated the number of cylinders; if the model number ended in 4, it was a 4 cylinder; if it ended in 6, it was a 6 cylinder; and, if it ended in 8, it was an 8 cylinder. Makes sense to me. So, a 1566 V-8 would be a misnomer. It would be a 1568. mike
Hugh MacKay
11-18-2007 14:01:18
Chuck: Don't let yourself get very excited about V8 diesels. None of them have been overly successful. Of all diesels over 100 hp in the past 75 years, 85% of them were inline 6s.
B.Jones said it for you, all those tractors IH put that V8 diesel in never tested as well at Nebraska as the same tractor with inline 6. The 6 is a naturally balanced engine, V8 are artificially balanced, and it just doesn't work in high torque engines.
Steven f/AZ
11-18-2007 13:22:40
IH 2-wheel drive v-8 diesel tractors were the 1468 and 1568.
There were some v-8 diesel 4x4 as well.
B. jones
11-18-2007 13:05:05
Yes they did. It was called a 1568. It was tested at Nebraska in May 1975. 150.7 Hp at 2600 rpm. 550 cu. in. The 1566 tested at 161 hp also at 2600 rpm but with the 436 turbo motor. I do not know if they ever made a 1586 with a V8. At Nebraska the V8 motor used more fuel and had less power.
